so he is lying to you that's for sure
the nozzle wouldn't block it after an hour.
first of all, if the price is right, buy it. nothing much can go wrong with these printers.
just look for exterior damage..
how many printing hour does it have? below 2000 basically means it is as good as new..
look at any exterior damage , are there cracks? are the belts ok? they should be tight. move the head around, does it move around smoothly? if not, put a little bit of sewing machine oil on it (take that with you!) and move the head again.
then i would say a used UM2 is worth between 800 and 1000 euros depends on the hours it has ran..
the problem he is describing is the PTFE piece.. that will clog up your prints..
just buy the thing as cheap as possible, buy the upgrade kit for 400, it will have a new feeder, new head assembly and this will solve all those issues.. that way you have a basically almost brand new um2+ for about 1200 to 1400 euros.
- 1
vany-chaotic 0
how can i delete a post T_T
Edited by GuestLink to post
