Posted
· use Ice Spray to remove objects stuck on glass
Hi Andreas,
I use 3DLac as well and I notice that the spray works great but if you get drops of 3DLac they will stick a lot more so try paying attention to those especially with XT because it can chip your glass surface.
ice spray: is it not just compressed air that causes ice when over pushing it?
I wonder if you can try to use the ice spray on the underside of the glass to see if it still works. This way the ice spray would not get in contact with the piece. I usually just rinse the underside of the glass with cold water in the sink and it helps to lower the temp even more.
pm_dude 27
Hi Andreas,
