Quality, quality, quality.
Personal I wouldn't touch it, some of the quality of metal parts produced is not there, check the Olsson block I think they are now doing or are in the stages of doing a 1.75mm nozzle block, then you just need the correct Bowden tube, and a feeder unit(if running a dual head), print off some bits you may need and your away.
Bear in mind if it's a cheap poorly produced nozzle you may get poor prints, and one reason for the Olsson block and nozzles is the improved flow of material and improved prints.
1
neotko 1,417
Aliexpress it's like an ebay mostly from china, asia sellers.
If you check the description of the second kit, it uses 12v 40W heater, so it won't work on um2 board.
There are plenty of china sellers that sell that ones. But the key to buy from aliexpress it's:
- Send them a msg to the seller shop and check how good/bad it's the support.
- Read, read, read the description.
- Check the votes and number of unit solds.
For more info about china shops check:
https://ultimaker.com/en/community/17068-making-your-own-ultimaker-what-not-to-buy-on-china-stores-personal-experience
Edited by GuestLink to post
