Are you using cura? If so what version?
Thank you :-)
I'm using Cura 15.04. Does the version of Cura matter?
Thank you :-)
What temperature, speed, and layer height are you printing at?
I never get those issues - I think you may be printing too hot but the problem is if you cool down you might also have to print slower - a lot slower. It depends what layer height and speed you are at now.
Thank you :-)
I printed at 210 °C (PLA), speed 50 mm/s, layer height 0.1 mm/0.04 mm.
So can I know what temperature is your PLA? And the speed you're printing?
PS: I think 50 mm/s is very slow, because it always takes 2-3 hrs for my sample (4 cm*6 cm* 3 mm)...
50mm/s is pretty normal. You can print 100mm/s but it depends on what sort of quality you are after and the nature of some designs work best printed slow.
You need to understand that prints take time but If you want faster prints then get the Olsson Block as you can print upto 4 x faster with a 0.8mm nozzle.
Your temp and speed is ok for 0.1mm but temp maybe a bit high or speed a bit slow for 0.04 mm.
Thank you for your kind suggestion, especially the Olsson Block and the temp and speed. I'll try a bit lower temp or a faster speed.
And do you think both of my problem (end of printing & flat surface) can be solved by changing temp/speed? Or this solution is just suitable for one problem?
The only time I have experienced a problem like yours is when therectile is an error and the printer stops causing a melted blob.
It looks over heated. Maybe you could show a short video of the printer finishing a print with the melted blob.
Is this ultimaker grey? There is a batch of grey that prints better at a lot lower temps.
Or maybe you temp sensor is out a bit.
Hi, here is the video of ending of printing: At the end, the nozzle still extrude PLA...
And sorry for my poor English. This ultimaker 2 is bought on 14/Sep/2015, with a white shell.
It definitely isn't retracting at the end. Have you made sure retractions are turned on in cura?
Also check retraction speed and length on the machine.
Default retraction speed is 25mm/s and length is 4.5mm
it also looks like you don't have skirt turned on?
Hi! I've checked the retraction, and reset it as default. Though it gets better at the ending (remaining filament became fewer), it still has very little string (can be removed).
And the skirt is turned on. I think because I changed the adhesion of the platform, so at the skirt PLA could not get out...
Generally you do get a tiny string.
Are you still getting the melted blobs on top?
Labern 772
