I have also tried to download the software after filling out all of the fields. After the captcha nothing happens. The download button does nothing, i can save its image with a right click but thats it. I'm using chrome if that matters.
There's a bug. I also noticed it. Just tick the " I don't want too share info " and you'll be able to download.
And as an extra tip.....lower the default speed for infill it's set crazy high by default...
- 5 years later...
cannot update cura .10
Why not, what's the problem?
SandervG 1,505
Hi Hydrain, thank you for your post.
Are you sure you filled in all the required fields?
If you select not to share any information, can you download it then?
If you select to do share info, but don't fill in all the required fields it won't let you download it.
Let me know if you can download it when not sharing any info.
I'll have our dev's look into it.
