You can get the pt100 in many places. 3dsolex.com and it's dealers, even e3d sell them.
http://support.3dverkstan.se/article/62-installing-the-olsson-block-kit
is absolutely right. You need a spare PT100B. When I got my UM2extended (after reselling my former UM2) there was no spare PT100B included.
This is a MUCH better instruction then the one given on the Ultimaker website. (That I was using since I purchased the upgrade there and expected it to work.)
The Ultimaker Store has that 1eur PT100B sensor here
https://ultimaker.com/en/products/spare-parts
but it's 37,50eur + VAT = 45eur + shipping = €48,90
By experience the UM store ships via Fexed B2B carrier. So It's something like 22+eur and I cannot receive it because I'm not a business with an office open every day Mo-Fr 8-16:00.
The shop doesn't seem to work with the network here. After login nothing happens.
3dSolex links to http://www.goodtube.uk/ for Europe. They don't list anything else but the Olsson Block.
http://www.imakr.com/eu/en/order is 55eur including shipping with no mention what shipping company they use.
...I just ordered it to my hotel room in Hamburg directly from Ultimaker.
There was no way to leave a comment during the checkout process to say,
that it MUST arrive before the congress is over (2015-12-30) simply because I'm
no longer in that hotel afterwards and the printer is needed DURING the congress.
Edited by GuestHi Marcus, I would get it from 3dsolex, also do you know what the wattage of the heater element?, it's worth upgrading to the 35W heater at the same time if you are running on a 25W or less.
How to check?
There are no markings.
What shipping company does 3dsolex use and where to find the PT100B in their European store?
If they use a regular parcel service instead of a courier and Ultimaker fails to deliver in time, I may need to cancel my order with Ultimaker and order somewhere else anyway.
Edited by Guestnow idea what shipper Carl is using.... if your in a hurry maybe check the resellers.
http://3dsolex.com/representatives
f.e. I see that Didier (belgium) has them in stock, mail our call him if yr in a hurry...
http://www.ideato3d.be/boutique/3dsolex-products/other-parts/um2-temperature-sensor/
The're cheaper at E3D - http://e3d-online.com/Spares/PT100 - but not in stock atm.
Ultimaker can't ship, I'm tring with iGo3D to have it shipped to the hotel while the congress is still running.
I got a PT100B from Ultiarjan and it works fine.
I had to sand it down slightly because it's a 3.01mm capsule for a 2.99mm hole.
You got another one? Cause I'm not Ultiarjan... But nevermind, it was obvious that you had tons of things spinning in your head;) Glad that I could help!
Chris
1
Sorry, I was in a hurry and just looking at the second to last user name in the thread without reading the content.
I'm currently experimenting with the nGen filament.
Edited by Guest- 4 months later...
I have exactly the same problem with the set screw jammed, could you please tell me where I can find this off-size micro-torx set because the allen key provided by UltiMaker did not work and it it turns in place as its size is small than that needed.
MarcusWolschon 7
Fixed it. I was able to borrow some off-size micro-torx set and remove the bolt.
The heater-cartridge slipped out more or less easily.
...the thermistor didn't. :(
Where to get a new thermistor and how to install it?
I have one of these expensive UM2 hotend-sets but it doesn't include a thermistor. Only the mechanical parts.
Image:
https://plus.google.com/photos/103982631119479761813/albums/6233004822427105441/6233004820129097314?authkey=CObdsbHW26WwFw&pid=6233004820129097314&oid=103982631119479761813
Edited by GuestLink to post
