Status says prints finished, but print is only 80% complete???
Posted · Status says prints finished, but print is only 80% complete???
First time posting after buying my Ultimaker and in need of some help.
First, if there is already a thread on this my apologies as I could not find it. There are a lot of posts about incomplete prints but I couldn't find any where the printer acknowledges the print as being complete when it's not.
I'm running an Ultimaker 2 which I've had for about 2 months and the only modifications I've made are installing the Olsonn Block (which then lead to replacing the thermocouple....). This print was my first large print utilizing almost the entire Z axis. I have the print settings down to a slow print in hopes of achieving high detail. The total estimated print time was about 17hrs. Printer settings are default (have not turned up temp or adjusted % flow) and I'll attach the slicer settings from Cura at the bottom. material was PLA.
The problem I had, and this is the second time I've run into this, is that the printer simply stops printing before the print is complete. the hot end returns to home and the Ultimaker 2 proudly displays "print finshed you can remove the print". The quality of what is printed is excellent. The last layer shows no signs of errors in any way.
I don't have much experience in Gcode but I did review the code briefly in Repetier and can at least confirm that no lines were lost in the saving process (I've seen other people suggest similar problems may have been caused by removing the SD card to quickly).
I have 2 question for the community. First, has anyone else experienced this and do you have a diagnosis? Second, can someone advise me on editing the G-code so that I can attempt to resume the print where it left off?
Cura Settings:
[profile]
layer_height = .1
wall_thickness = 0.8
retraction_enable = True
solid_layer_thickness = 1.2
fill_density = 50
print_speed = 40
print_temperature = 210
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 70
support = Everywhere
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 2.85
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100.0
nozzle_size = 0.4
retraction_speed = 40.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0.0
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 50
bottom_layer_speed = 20
infill_speed = 50
solidarea_speed = 15
inset0_speed = 30
insetx_speed = 60
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
perimeter_before_infill = False
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 20
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.22
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G1 F200 E3 ;extrude 3mm of feed stock
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
end.gcode = ;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
T1 ;Switch to the 2nd extruder
G1 F200 E10 ;extrude 10mm of feed stock
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
M117 Printing...
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 3rd extruder
G1 F{travel_speed}
M117 Printing...
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
G1 F{travel_speed}
M117 Printing...
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
    My first guess would be, that the gcode is incomplete. Ether Cura did something wrong or it didnt copy completely to the sdcard. You could load the gcode in cura to check this.
    @ Aogra
    My thoughts at first too, but I checked the Gcode and all 2400 layers were present.
    I went to do another print just now and discovered that the nozzle was clogged.  Maybe it is possible that the printer went through the motions of completing the print but no material was extruded for the last 500 layers or so.  I would think this would cause an error way before it could run through all 500 layers though, either an overheating error or something.  Plus the nozzle and the print looked in good condition when I found the partially completed print.
    I ended up breaking the print into 2 small parts which I'll join later.
    Posted (edited) · Status says prints finished, but print is only 80% complete???
    I am brand new to all of this and just want to echo the same problem.  I've tried 3 different files that were STL files from thingiverse, they look good in Cura, but stop short and printer says that it's complete.  Your suggestion of halving the print is something I'm not sure how to do yet, but will have to look into.   Thanks for starting this thread, perhaps others will encounter and know of a fix. Also, I want to add that this very much doesn't appear to be an extrusion issue. The print is coming out perfectly fine and can start a new print right after with no problems or signs of any clogging. I've watched it hit this point so I know it just thinks it finished instead of going through the motions with no extrusion for the last layers.
    I'm having the same problem, and my printer stopped around the same percentage. I'm using an Ender 3. Nothing else is wrong. My print is really small, too.
    I sliced with Cura just like the other people on this thread (a recent version), and I think it must be a Cura problem? That's the only common denominator I can see.
    I designed this model myself and I know it's not broken either, so idk.
    Picture attached so you can see what I'm talking about.
    I have this same issue, and it says it is 100% complete. I have an Ender 3 V2 Neo, brand new, only two other prints done
    Might try reaching out to the Creality community about that issue.
    This thread was about a issue specific to UltiMaker machines
