Yeah its something that I always add to my drawingsbut can be hard to judge. Nozzle temp vs speed can have an effect also
yellowshark 153
I have not read the link "this" but any circle will always give you greater inaccuracies than a straight line; it is inherent in the way a 3D printer prints a circular geometry. And yes as mentioned other print settings will affect the percentage error. The only thing you can do is to increase the design diameter until the desired diameter is achieved. Irritating yes but once you have done it a few times you should find you will get it right within three or four attempts - and reduce the height in Cura until you have got the design dims to where they need to be
1
Thanks to both, we increased the inner diameter by the desired amount and it produced good results. Thanks for all your replies.
At a guess, do you think the UM2+ will have a same problem or is it impossible to tell?
It's the nature of extruding plastic. It's kinda acts like chewing gum an pulls in on circles.
Better cooling, more accurate temp sensors and feeders will always help to some degree.
Excellent, thanks Labern. Very much appreciated.
Labern 773
It's normal for inner holes to be smaller then outer dimensions when it prints.
Have a read of THIS as it explains it quite well
Edited by GuestLink to post
Franny500 9
Thanks Labern that is an interesting read.
I asked my more technical (than me, who isn't ?) friend and he was a bit surprised at the difference in the tolerance between outer and inner diameters. But thanks again for the reply, some interesting stuff to read there.
