There is a heated bed kit that you can get from 3D Solex or one of his re-sellers if you end up having to many problems.
- 1
Yes blue tape should do the trick, i find that it's sometimes harder to remove than on the heated bed.
Just make sure your first layer is good and squished and you should be good to go
Thanks everyone for answer!
Releveling the bed helped and now print stick very well.
Have a nice print!
Using a brim will also help if you have problems again
Labern 774
Blue tape only with no glue should work just fine.
Clean the bluetape with isopropyl alcohol first as it has a wax coating on it which needs removing.
Try that. It is doesn't work then try releveling the bed a bit closer. You can also try a slightly higher nozzle temp to help it stick and after the first layer lower it back down slowly.
