Thanx, it seems this would be the cooler element:
Can I attach it with this, you think?
http://nl.farnell.com/servisol/200001002/heat-sink-compound-none-silicone/dp/3821523
Or maybe is it just easier to replace the whole stepper driver like this?
@Hanne here is shop where you can by:
Alu cooler: http://www.reichelt.de/IC-Kuehlkoerper/ICK-SMD-A10/3/index.html?&ACTION=3&LA=3&ARTICLE=113625&GROUPID=3381
and Special glue: http://www.reichelt.de/Waermeleit-paste-folien-scheiben/WK-709-5ML/3/index.html?&ACTION=3&LA=3&ARTICLE=35418&GROUPID=3384
Another source: http://www.watterott.com/en/Heatsinks-6-3x8mm
This adhesive works well: http://www.arcticsilver.com/arctic_alumina_thermal_adhesive.htm
gr5 2,243
That is an important part. That part it fell off is called a "pololu" so try googling:
pololu heatsink
I think they are glued on with special heat conducting glue. You could instead google for that.
