DidierKlein 729
I agree with @Labern, he's pretty good.
The UM Robot is not an easy print, it's small, has a lot of overhangs.
What is the layer height? at 0.1mm and 30mm/s as said and lower the temp as much as possible will give a better result. If you are using smaller layers, overhangs are harder to manage
Labern 772
Your robot isnt to bad. but at 30mm/s I normally print at 190 - 195.
Have A look at This article as it maybe of some help.
