you are prolly right cloakfiend.
For instance this little idea: square variations (a human touch) comes more close on what I want to do now, but on a grander scale.
So I found this site where they sell larger pla plates that I hopefully can heat up in some way and generate adjustments instead of printing a 15cm x 15cm plate.
cloakfiend 992
ahh, i love mikado! and the chocolates too! i'm not 100% sure what you mean, but Id get a laser cutter if i was working on only flat stuff. There is no point spending hours doing what can be done in seconds. the overhangs wont let you print your kind of setup in one go using fdm. and as for designing in 3d you can effortlessly create what you are doing wth dynamic simulations or active realtime dynamic simulations if you want total control. There are always multiple methods of creating what you need, it usually comes down to what is most achievable vs most affordable.
Edited by GuestLink to post
