Copper Grease
XYZAidan
Posted · Copper Grease
My Ultimaker Original + kit came with copper grease, but the instructions never involved it. I've built the bot and it works great, but where is the copper grease supposed to go?
Bonus question: Do I ever have to apply lubricant to the linear rails?
Thanks
    When assembling threaded components such as a nut and bolt apply copper grease to the threads, this can prevent the components from rusting and seizing together. Copper grease can withstand temperatures of 400 C degree
    Both. Just one drop for each shaft. Also try not to get any on the gears or they will splip.
    Posted (edited) · Copper Grease
    Weird on the help area don't say anything about the head x/y oil. I been doing it for a year and mine works great...
    https://ultimaker.com/en/support/150-lubricating-the-axes
    For the Z screw I use a chain oil like @Dim3nsioneer said on a post
    https://ultimaker.com/en/troubleshooting/15973-z-axis-banding-again#reply-107217
    And works like a charm.
