Thank you I'll try!
I might have understood you incorrectly, but you asked for skipping the infill for bottom/top layer and the solution i gave you is how you do that.
Thank you nallath, and sorry for my bad english, my fault.
There is the plugin named "skip infill" here http://wiki.ultimaker.com/CuraPlugin:_Skipinfill
that print to fill every "n" layer. so for example, I can print 0.1 but infill 0.2 it's ok?
it works with bottn and top layer also?
Is that plugin compatibile with cura 15.04.x ?
is it possibile to view a preview result?, because in preview if I use tha plugin the preview layer don't change
Excuse my bad english
Cristian
Edited by GuestI've never worked with that plugin, so I don't know how it works / should work.
ok I do same 3D prints for test, I think this best the way
Thank you anyway
Cristian
nallath 1,123
You could just set the infill to 0% (and top/bottom thickness to 0 as well)
