A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
sergiucip 0
I believe i found the settings:
In configuration.h
// #define DEFAULT_AXIS_STEPS_PER_UNIT {80.0,80.0,200,282} // default steps per unit for ultimaker2 (for 8 mm rods)
#define DEFAULT_AXIS_STEPS_PER_UNIT {80.0,80.0,200.0*8/3,282} // default steps per unit for ultimaker2 (for 12 mm rods)
Testing tomorrow
