Naval Cannon
Dweldz
Posted · Naval Cannon
Thanks
Post processing on the barrel was just the muzzle end which was on the build plate.
I am lazy when possible.
On the carriage and wheels a little razor knife work and 100 grit sand paper not a lot.
The key to this is print both the carriage and wheels in black and then go back and paint the wood on, around the bolts heads etc.
I used Testors # 1140 brown, If you do just one coat and the black print shows thru some and gives it a wood look.
I will ad to prints.
