Making the Ultimaker+
Posted · Making the Ultimaker+
Now that I have enough experience of the standard Ultimaker, I really want to rebuild my Ultimaker to a Ultimaker+ with a Z length of about 50cm.
The only thing missing is the Trapezium thread for the Z-axis, where can I buy an exact same but longer version ?
I have a special project that needs the extra hight, and I don't want to spend time glueing parts together :)
    Still working on the drawings, but it is the hight I want, and I still need to draw the thicker side panels, and new Z-level bearings.
    I got my eye on some bearings with supported rods, to account for movement lengthwise, this means that I will have to do a small redesign of the print bed.
    If you have problems with me putting the name "Ultimaker+" on it let me know :)
    it still will be 95% made from my own Ultimaker.
    • 1 month later...
    After some time, I started back on my Ultimaker+ build,
    I received all the necessary parts I need, and I made the 3D drawing to match the parts I have,
    so I can CNC the case parts.
    The outer shape is already cut, and only need all the mounting holes and openings.
    Well, I have finished the basic build of the Ultimaker+, and have now doubled the height :)
    I transplanted all (well most of) the parts of the "old" Ultimaker into the new one, I did have to make some alterations, mostly because of the thicker 8mm Perspex.
    surprisingly most of the wiring was long enough to accommodate the extra height, and I only had to lengthen 3 wires from end-stops
    I did have to make a complete new printing plateau, for the supported rod bearings, this turned out to be very easy, as I kept it as simple as possible.
    The plateau feels very sturdy, and I think the supported rods feel very solid, there is no wobble in the Z-stage at all, and it moves smoothly up and down.
    I still will need to do a little tweaking here and there to get it just right, and redo some details I want to improve.
    overall I am very happy with the result, and hope the prints will look as nice as I hope they will be :lol:
