yellowshark 153
In the past I have found the following to help with this
run the walls at 1.6
slow down, say 30mm/s
set your speeds the same, so infill/inner speed/outer speed as all 0 and print speed 30
run as cool as you can. I was testing a new filament today and started at a temp of 200 which looked fine but I dialled it down in steps to 180 which also looked fine and I chose 185
darkdvd 983
Search "z-scar" in the forum
