To put it in a nutshell, the STL-Tweaker uses the mesh format for the calculations.
The function >tweak< manages the internal workflow, while the other functions are callable form external python code.
Notice the function >arrange<: This one reads the facetts of the mesh format and puts each facett into a 4x3Matrix (Normal vector plus 3 vertices)
If you need more infos, feel free to ask!
nallath 1,118
It could use a bit more documentation in the functions. I'm willing to give it a go to make this into a plugin, but I will need to do a bunch of re-factoring to get it to work (eg; I don't want the plugin to load a file, I want it to use an already loaded file (so it can work for all Cura supported file types)
ChrisSalzburg 12
I'm glad you like the STL-Tweaker. I will publish a extended version of the Tweaker in the next days, which supports also the 3mf format. In this version, the internal work process is clearer.
If you wish, I'll send you a preliminary STL+3mf Tweaker-version (it works just in Linux right now)
