Labern,
I'll try alcohol on the tape tonight. With the tape, you don't heat the bed, correct?
Thanks
Alex
Labern,
Thanks
Alex
Correct.
I never use blue tape for woodfill... What are your print settings?
I'll get them tonight.....
Correct.
Ok. I've got it to adhere to the tape with alcohol, somewhat. Maybe should I slow down the first layer? I know people say if you leave the filament in the hot end for too long it'll burn, but how long does it actually take to burn?
Not very long but as long as it's moving a find it ok.
What temps, initial layer height and speed r u using?
Labern 774
Did you clean the Blue tape with isopropyl alcohol to remove the wax coating?
You may need to up the temp a little.
I normally use Glue on the heated bed. It is a bit hard sometimes to get it to stick.
