It´s the same thing under file menu. Export is there but can´t be clicked on.
Hehe just found the problem.. Terms was expired and had to be accepted
1
May the following works? Expand the body tab, and right click the body(s) you want to export.
- 5 weeks later...
flowalistik 181
I use Fusion 360, and to export an STL file just click the button "Make" (the third one starting from the right part of the menu options) and that's it. You can choose the mesh quality and if it's for fast prototyping you can connect Fusion 360 to your slicer so you won't have to save the STL, open Cura and import the STL.
Job_van_gennip 23
It is probably under the file menu and then something called export
