What bottom layer speed do you have? Print speed?
Nozzle temp? Bed temp?
What height do the fans reach 100%
Hi Labern
PLA Silver gray from Form Futura & from Ultimaker
PLA parameters :
nozzle 0.4mm
layer thickness 0.1mm
first layer thickness 0.2mm
top/bottom shell thickness 1.2mm
nozzle temp 210°
bed temp 60°
first layer speed 20mm/s
speed 50 mm/s
fill density 30%
fans start at 8mm high & progressively reach 100%
Your fans are starting very high. The should start on like the 3rd layer the progressively get to 100% by the 10 lever or so.
neotko 1,418
That's because the heat of the bed. If you really need overhangs near the bed
a) Print pla with blue tape, bed off, fans at full after layer 1.
b) If you need the Bed on, just print like you do but set fans at 100% at layer 2. For this you need to be sure the pla it's stick like glue to the bed so the fans won't unstick it. Paper towel + window cleaner and short (microseconds) 'puff' of hair spray and clean the bed with that. The print won't come out until the bed cools down to 30C and 27C to be sure. Don't try to take it out before that or you can actually dmg the glass.
Also of course you could just change the speed for the first 15 layers or so, and then change it again. But that would need more gcode tuning than what it's worth.
gudo 246
Hi Neotko
Thanks! your explanation is clear and precise, it gives me a track,
I'll test it
freeform4u 4
As well turn the parts 90°, so they go with the airflow. If you print 2 parts at the same time move them that they get a bigger distance it helps to get more cooling for each part. Use a bigger nozzle can helping a lot.
gudo 246
Hi Freeform
I try to turn yet and also to keep distance the problem stays
the only time I get a good result is when I printed a circular form with the overhang chamfer
starts on bed
