Thanks. It sounds logical.
Now to increase the countersinking in the heat plate, so that the glass plate lays flat on it without resting on the corner screw heads, so that I can utilize all of the build plate without the first layer getting squashed to zero thickness near the corners.
I'm guessing this will give me a more even and maybe higher build plate temperature as well.
nallath 1,125
Brim influences this, same goes for the bed clips.
