Thank'd Daid, as i said, i am a noob...
I really don't know how to get in this set up.
This is a new world for me. :?
Which is why I created the website, it builds Marlin as specific configurations you want. That's a lot easier then messing around with the Arduino stuff. It also adds a few files in the windows zip that help with installing the firmware. Or you can download the resulting HEX file and install it with Cura's "install custom firmware" option.
Right, in cura, i open a custom firmware?
Into MArlin V1 there are boot loaders 5 ones
Which file i put?
I try.
Thank's for all Daid.
anyone care to point out to him the melting point of PEEK?
275C should be safe. And the V2 hotend transfers a bit less heat to the PEEK then the V1 hotend, giving you also a potential higher running temperature.
But indeed a warning would be in place. Messing with your firmware could irreversible damage your machine.
i am still learning ardiuno..
For temperature, i modified all the extruder body. I believe in the end that i will also need 2 head because there is a cleaning problem with the PLA after ABS or PMMA. Few of it stays into the heater and make problems.
- 9 years later...
GregValiant 1,320
This is a 10 year old thread.
On 10/29/2022 at 4:12 PM, GregValiant said:This is a 10 year old thread.
And yet, it got a reply! 😉
guillaume.dolnet 0
So, i am on win7.
I download sketc_nov20a and i am searching the file who content the machine spec?
Anyone could help me?
