I'm assuming it is reading back the correct temperature. You can check this in advanced menu system.
If so then there is usually an open somewhere between the circuit board and the bed circuitry. It could be the wires fell out at the circuit board - especially if you put them in yourself - many people don't insert them all the way.
Or if you haven't messed with it yourself then it's more likely at the terminal block (the block with 4 screws) which is soldered onto the heater circuit board inside the heated bed. It's easy to get access to it - jsut remove the 3 leveling screws and the cable hold-down (2 more screws).
Usually you need to reflow (reheat) the solder on that connector - or sometimes one of the 4 screws (on the larger 2 wires) is a bit loose or one of those larger wires fell out of that connector. I mean every time the bed goes up and down there is a tiny bit of stress on those parts there.
ok, thanxs for the info. I'll break it down a bit later and see if that is the problem.
gr5 2,210
