Exploring new Cura
foehnsturm
Posted · Exploring new Cura
Just started to play around with some settings. Of course the per object settings concept is one of the most interesting features.
PLA & BronzeFill, per object settings for extruder and fuzzy skin.
Printing with 0.4 and 0.6 mm nozzles right now. And I would like to use different layer heights but this setting is not available per object.
@nallath: Are different layer heights per object prevented by the slicer algorithm in general or did you just decide not to offer it?
(S3D handles varying heights)
    The slicer doesn't handle it. If you print one at a time it should be possible I think, but for all at once it's a bit tricky right now.
