The motor pullies i didnt check..
Everything is tight, i am now downgrading the firmware to 14.09 read something in a different post.
Thank you in advance
What did you read that advised you to use firmware from almost two years ago?
Cat find the post, But i am noe in a state that i am tryong everything. Atleast we can excluse the machine software if it still doesnt work
Cant find the post, But i am now in a state that i am trying everything. Atleast we can exclude the machine software if it still doesnt work
Got it, forgot to repair the slice, tnx for thinking
neotko 1,418
Did you check the x/y motors pulley screws? Also check if there's any oil on any belt. Check the full 10 pulleys. The hard part it's to access the motor pulleys. I would call the seller just in case.
