Shifting nozzle
wlaagewaard
Posted (edited) · Shifting nozzle
image.thumb.jpeg.c27883cab21d3a3eef14fcf02bb3c777.jpegHi
I just bought a UM2 and when a print a bigger design it always shifts 2 cms up at the same position.
I checked screws
Checked pully short belts
I upgraded firmware
Tried different speeds
It's brand new..
Wayne
    Posted · Shifting nozzle
    Did you check the x/y motors pulley screws? Also check if there's any oil on any belt. Check the full 10 pulleys. The hard part it's to access the motor pulleys. I would call the seller just in case.
    Cat find the post, But i am noe in a state that i am tryong everything. Atleast we can excluse the machine software if it still doesnt work
    Cant find the post, But i am now in a state that i am trying everything. Atleast we can exclude the machine software if it still doesnt work
    Got it, forgot to repair the slice, tnx for thinking
