How to prepare to build an Ultimaker
3design
Posted · How to prepare to build an Ultimaker
Hi
In two weeks I am going to build an Ultimaker, during a course in the FabLab Lucerne.
If you were in my position - being quite a beginner with anything concerning 3D printing: How would you prepare for such a course? Which subjets, issues such as processes, software, methods are of prime importance to have at least a notion of?
Which sites, forums, blogs etc. do you recommend me? Maybe you know somebody who build one himself and described his experience?
    I recommend daily exercises, a healthy diet and don't forget to bring a big stick - there are bears roaming near Lausanne :mrgreen: :mrgreen: :mrgreen:
    yes, exercise is necessary, even for bears, since lausanne is about 160km from lucerne, at least for crows... wondering bears will needs to walk for 200k+
    Hi
    are you holding the course, or is a experience UM user holding the course and you are participating?
    reading and re-reading the assembly wiki helps a lot, the rest depends on your answer above.
    I agree with Joergen. Reading the wiki and the assembly instructions over before you start building is a great idea. I just finished building mine and it wasn't so bad. Reading ahead would have taken a lot of stress off for sure. Just seeing how it should and will turn out before actually doing it will make things easier.
    Also get a lot of work space. I can't count the amount of times I knocked stuff off or lost things because I was working on a tiny desk.
    timelapse :
    http://vimeo.com/30945234
