This is very common after installing the olsson block and usually happens when the fans come on which is typically the second or third layer. The problem is that the olsson block is touching the fan shroud somewhere. I would start heating the nozzle to 150C (in case there is plastic in the threads) and then remove the front left thumb screw so you can get good access to the round nut that positions the olsson block height. Also remove the 4 screws that hold the fan shroud and let that hang down by the wires.
Now make sure the nozzle is above 140C and rotate that round nut using something metal, long and skinny. Like a very small screw driver. Rotate it both ways a bit to make sure it isn't at the end of travel and then rotate it such that the olsson block moves up as high as it can go or possibly 1/2 turn less. This whole thing was designed for when you have dual nozzles and you need to get them the exact same height within .01mm. Since dual printing never worked you want the nozzle as high as it can go so the olsson block doesn't touch the fan shroud.
Consider possibly putting a thin strip of kapton tape on the bottom of the olsson block to give it a little bit of insulation between it and the fan shroud.
when you put the fan shroud on push down on it while tightening the 4 screws that hold it on. Even getting another .1mm might be enough to get rid of your "heater error".
Test it by heating to printing temps (say 220C) with fans on 100%. It takes 30 seconds without the nozzle heating up to get the error.
Alternatively get a more powerful nozzle heater - UM2 used to come with 25W heater but some of them are as low as 18W due to manufacturing variability. Get a 35W from 3dsolex or Ultimaker.
1
gr5 1,876
