build plate temperature limit after firmware update
ckonecny
Posted · build plate temperature limit after firmware update
Hi!
I recently purchased the Ultimaker 2 Extrusion upgrade kit, installed it in my UM2 and very glad with it.
however, i just recognized that since the firmware upgrade to 15.04.5 that i was supposed to do straight before using my UM2+ the build plate temperature now can be set only to a maximum of 100°C.
Well, I am using a permanent build plate cover sheet which requires a temperature of approx. 112°C for optimal stickiness of ABS.
the menu on the printer does allow only a max. of 100°C and even if using simplify3d any attempt to set higher temperature than 100°C does not exceed this magic threshold now.
does anyone have a hint for me, how to shift this limiting threshold?
thanks a lot in advance!
Christian
    Save that somewhere! You might need to downgrade to "tinker 16.03.1" at some point in the future if a future release of tinker doesn't let you go above 100c bed temp.
    It's not too hard to build your own firmware. The max temperatures are extremely easy to edit (in Configuration.h - very well commented) once you figure out how to build Marlin.
