yes. You want tweak-at-z.
Flow rate can be changed. It's a gcode. You can also change it on-the-fly from the TUNE menu.
So tweak at Z is from what i've gathered something you set at the begining of the code and cant change after you click print, correct? I'm asking about a more on the fly type of thing.
Where is the TUNE menu? I can't find it.
gr5 1,967
