ggabriele3 0 Posted May 16, 2016 in Cura showing an incorrect build area I'm using the latest version of Cura with a Printrbot Simple Metal. My printer has a build area of 152.4mm^3. This is set properly in my EEPROM M211 settings. In Cura's Machine Settings, I have the Build Area set to 152.2.4mm^3 as well. However, Cura will not let me print anything larger than 149.9mm. Even with skirt set to zero, a print with 150mm in X and Y is showing up grayed out, and "Scale To Maximum" scales it down to ~149mm. Is there a way to get Cura to give me the correct/full build area? Share this post Link to post Share on other sites
gr5 896 Posted May 16, 2016 in Cura showing an incorrect build area Look in the machine settings. You can set the dimensions of your printer (diameter) in there. Share this post Link to post Share on other sites
ggabriele3 0 Posted May 17, 2016 in Cura showing an incorrect build area Look in the machine settings. You can set the dimensions of your printer (diameter) in there. As I mentioned in my post, I did that already. Also it's a square bed, not circular. Share this post Link to post Share on other sites
