Love DesignSpark but....
Posted · Love DesignSpark but....
Hey there,
I really need some advice please!!
I use Design Spark to draw all my prints. I love the interface, its very user friendly and I get great results. The issue I have is that I design for other people and once I have saved the design, I cannot edit it if my customer wants to make changes. Im going crazy and wasting a heck of a lot of time re-drawing the designs.
So, is there a really simple, very easy program I can use to edit my stl or rsdoc?
I have played with Meshmixer and Blender but its all too complex for me!
Thanking you all :)
Cheers
    Spaceclaim can deal with (some..) STL and all rsdoc, so it can be used to f.e output a .step from a rsdoc. but a legal copy is pretty expensive.
    The best free option that outputs many formats a.o. step is Fusion360 (free for makers and small business i believe).
    http://www.autodesk.com/products/fusion-360/learn-training-tutorials
    If you correctly save your designs in the native DesignSpark Mechanical format (RSDOC-files), then there should be no reason why couldn't edit them afterwards. I have made hundreds of changes to my existing prototypes.
    So, could you verify that you save each design as an RSDOC-file first?
    If that is okay, but you still can't edit existing files, then the problem is probably somewhere else: wrong user rights on a file or directory? If so, try copying them to a FAT32-formatted device (USB-stick), and back, that removes all user-rights.
    I would suggest for each design and each version of a design to save the files as follows:
    - Always save it as an RSDOC-file first (double check you have the correct format, RSDOC, since DSM defaults to the last used save-format).
    - Then save it as a JPG-file: this makes it a lot easier to browse through your designs with an image viewer and select the correct item for further editing. Very handy if you have hundreds of files.
    - And only then save it as STL for printing. You can't edit STL-files in DSM (or at least not without a lot of problematic tricks, and with loss of design-info).
    Geert
