Hi @Dirtrider07, welcome to the forums! @SJDrummond too!
Could you check if you have uploaded the correct firmware?
The UMO with a heated bed has a different Z-motor and you should upload the firmware for the UMO+. Perhaps that should help.
About the max temp error, when does this happen? Could you upload a picture of the top of your printhead? Did it do this from the start or only occasionally?
And Sean, linking your axis issue to your hot end doesn't really make sense right now for me. For me what would be most obvious is if during installation some belts or pulleys got loose.
Are your short belts tight?
Could you run by all 12(!) pulleys and tighten the set screws like you have never tightened anything before? Remember not to forget the ones on the X and Y motor (but you probably should start with Y). Good luck both!
Dirtrider07 0
Hello,
First time to post and I would like to piggy back onto this post as well. I just inherited a UMO with the upgraded heat bed, currently getting max temp warning from the bed that would not allow the printer to run, so I disabled it, I will tackle that after this issue.
I too am having an issue with distance on an axis. Mine is the z(height). When calibrating the bed as it asks you to move the bed up to the nozzle you can do it in .2 or 10mm. When I push Up 10mm the plate actually moves up about 24mm???? Now when I try to print a 10x10x10 cube I get a 10x10x26.5.
Please help us out on our issue.
Thank you all in advance
