Thanks gr5,
I will look into that. At first glance it seems very helpful. Does this replace my Cura firmware on my machine? Anything I should know or be aware of specific to the Ultimaker 2 with an upgrade kit to make it a 2+
Thanks gr5,
Cura is the slicer. Marlin is the firmware. But you do use Cura to upload a new firmware (a new marlin).
Tinker marlin is great. Just try it. There's no downside.
My printers were all working fine before the plus kit. If you want a cheaper version of the plus kit you can try my alternative (read the long description at the bottom):
http://gr5.org/store/index.php/ultimaker2-plus-upgrade-kit.html
gr5 1,999
Get tinker Marlin. It lets you resume a failed print. I think it even keeps track of the layer that you quit on but perhaps only if you do a regular abort sequence. There are many other great reasons to get tinkerMarlin and no reasons not to (there's no learning curve):
https://github.com/TinkerGnome/Ultimaker2Marlin/releases
