Ninjaflex
Starwind0
Posted · Ninjaflex
Okay, I am getting pretty frustrated trying to 3d print with ninjaflex on the UM2 extended. I'm very experienced with 3d printing, with 5 years building these machines, starting with Reprap.
The recommended temp of 230 seems pretty nuts, as it will come out as liquid.
I got it printing at 200, sides looks okay, but the internals are just whispy webs. Mostly looks like I dripped a wax candle inside.
I'm just looking for a settings list for S3d that say Use this! And at-least get me 90% of the way there. If I have to tinker the settings over weeks I might as well use my Mendelmax instead. The UM2 I bought with the aim of not tinkering, and tinkering on the MM2.
Thanks!
    Posted · Ninjaflex
    Actually I think your PT100 is out of range. Mine shows about 15°C lower than it should and I never got Ninjaflex liquid. Is the temperture reading stable?
    I print Ninjaflex at 15mm/s or maybe 20mm/s but not faster. Also, if you have not yet, use some corn oil or similar (organic oil with high smoking temperature) to lube the Ninjaflex inside the Bowden tube.
    Posted · Ninjaflex
    Agree with all the above - I use an IRoberti filament cleaner (see youmagine) with light oil (in my case WD40) and a modified UMO extruder and a temp of 240 and a .6mm nozzle and I get a passable result - did a 19 hour print with it last week.
    Not as good as direct drive, but workable.
    Rubber down a bowden is always going to be 'tricky'.
    Semiflex is easier as it is a stiffer filament, but it is also much harder.
    Play with retraction - pulling rubber down a bowden is also not necessarily the best.
    So you have picked a tough filament for a bowden setup.
    Possible, but needs tinkering.
        • 21 replies
