DidierKlein 729
You can also do this:
Heat up to lets say 180°c and take a piece of filament, put it against your nozzle and make it melt on the areas you want to clean then cool it down like you do for atomics and continue pressing it on the nozzle, when it cools down the burned plastics will be caught by the melted plastic.
Then pull the filament gently and it should peel off the residues.
This can probably also work if you only heat up to 140°c and "brush" your nozzle with some filaments
gr5 1,841
You only need to heat it up a bit and then you can pick it all off. 100C or even only 80C is plenty. boiling water or just a hair dryer. Not too hot to touch or maybe just a little too hot to touch.
