I have a 2+ and when I converted it from the basic 2 I had to load the firmware 3 times to stop the "bed" from rising and striking the nozzle. It had assumed that I had a U2 extended and after I had reloaded the firmware for the the third time it accepted it. Remembering this I reloaded the firmware 3 times and the problem was gone, it now works as an Ultimaker 2+ should i.e. impeccably. Many thanks for your prompt reply!!!!!.Did you install the firmware?
What printer do you have?
Downloaded the 1506 version and the loading material and reversing material are reversed. reset to factory,same thing.
HI', it was 15.04.6 I was using. But when I was converting from U2 to U2+ I had to load the firmware 3 times before it accepted. Remembering this I did the same thing and the problem was solved. I now use 2.1.2. I did check that I had the correct model each time but it seems not to accept the firmware the first time. Thanks again for your info'.First of all, don't use 15.06, it's a buggy mess. Use 15.04.6 or 2.1.2.
Second, you likely chose "Ultimaker 2+" when updating the firmware of your "Ultimaker 2", or vice versa.
IRobertI 497
