Build of libArcus fails for SuSE 13.1
MEgg
Posted · Build of libArcus fails for SuSE 13.1
I tried to build
https://github.com/Ultimaker/libArcus
Had to install newer cmake because of
"CMake Error at CMakeLists.txt:2 (cmake_minimum_required):
 CMake 2.8.12 or higher is required.  You are running version 2.8.11.2"
This was ok then with
cmake-2.8.12
Then:
"  Could NOT find PythonInterp: Found unsuitable version "3.3.5", but required
 is at least "3.4.0" (found /usr/bin/python3)"
Installed python 3.4.3 which was ok then.
Now I get:
-- Looking for include file pthread.h
-- Looking for include file pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found PROTOBUF: /usr/local/lib64/libprotobuf.so
-- Found PythonInterp: /usr/local/bin/python3.4 (found suitable version "3.4.3", minimum required is "3.4.0")
-- Found PythonLibs: /usr/local/lib/python3.4 (Required is at least version "3.4.0")
Traceback (most recent call last):
 File "[...]libArcus-master/cmake/FindSIP.py", line 8, in
   import sipconfig
ImportError: No module named 'sipconfig'
CMake Error at cmake/FindSIP.cmake:58 (MESSAGE):
 Could not find SIP
Call Stack (most recent call first):
 CMakeLists.txt:23 (find_package)
-- Configuring incomplete, errors occurred!
I have installed
sip-4.18.tar.gz
from
http://pyqt.sourceforge.net/Docs/sip4/installation.html
Any pointers what may be missing here?
I found
https://aur.archlinux.org/packages/arcus/
but obviously this still fails and there is no solution.
    Posted (edited) · Build of libArcus fails for SuSE 13.1
    We're working on a fix, but right now we only have one for Windows.
    Can you put some kind of "warning sign" to
    if parts are not compileable for Windows or Linux.
    Would have saved me a lot of time.
