Cure All Version Crash on my system. Please Help
erl
Posted · Cure All Version Crash on my system. Please Help
Hi! I cant seen to get my Cure to run. I tried Cura 2.1.2 and it crash ( Cura.exe has stopped working )
I also tried all the older version of cura and it also crash ( pythonw.exe error ) I updated my graphic card but still having the same problem. I really dont know what to do. Please help.
    i have the same issue since yesterday!
    I tried everything, the 2.1.2 release give me this "cura.exe has stopped working" and 15.x.x give back "pythonw.exe stopperd working" or something like that...
    Before i had no problem at all, i do not change anything on my pc recently...
    Im using win10 64bit btw
    Have the same problems.
    And there are no driver updates for my pc.
    Getting a bit crazy of all the problems my ultimaker 2 has lately.
    Cura 2.x needs a higher version of openGL, so if your video card is to old it simply can't be supported.
    As for old cura issues, I have no idea what could be the culprit there. I only did a tiny bit of work on that.
    i updated my gpu driver to the latest (im using a radeon HD7870, win10_64bit) and the problem remains...
    This time Cura crash after 20sec or so, before was crashing after 4 or 5sec.
    i am reading now the cura log and see these lines:
    2016-07-08 09:56:17,329 - DEBUG - Attempting to kill the engine process
    2016-07-08 09:56:17,329 - DEBUG - Killing engine process
    2016-07-08 09:56:17,331 - DEBUG - Engine process is killed. Recieved return code 1
    2016-07-08 09:56:17,331 - INFO - Backend crashed or closed. Restarting...
    2016-07-08 09:56:17,433 - DEBUG - Attempting to kill the engine process
    2016-07-08 09:56:17,471 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
    2016-07-08 09:56:17,505 - DEBUG - Backend connected on port 49674
    2016-07-08 09:56:31,718 - DEBUG - Autosaving preferences, instances and profiles
    i notice that those lines are repeted every time the program crashes, maybe the problem is CuraEngine.exe?
    Did your Antivirus recently update itself?
    Have you tried disabling your Antivirus and then running Cura?
    I haven't seen any stealthy updates by Windows 10 recently, so its (probably) not that.
    Nope, that's normal behaviour.
    PROBLEM SOLVED!!!
    it was a program called "PlaysTV" that made cura crash...
    Hi. Sorry for the late reply. Here is the logs. Hope I did this right. Thanks
    https://www.dropbox.com/s/rjjbn27f50g07hf/Desktop.zip?dl=0
    -_-u... It is the PlaysTV. THANKS iCe_00 ! After uninstall it. I haven't got that problem.
    No need to unistall, just close it when you don't need it ;)
    Hello guys i have just installed cura 2.6.2 and i have some crash issues:
    This is the cura log:https: www.dropbox.com/s/4stwx3f1wqky1oq/cura.log?dl=0
    and this the dxdiagnose txt:https: www.dropbox.com/s/68zjbl9dp30ybyc/DxDiag.txt?dl=0
    please i need your advice. Thanks in advance...
        • 24 replies
