Also look at your object in X-Ray View Mode in Cura for any Red areas. Those would be problems with your object that Cura can't resolve: holes in the mesh, stray lines, non-solid areas, etc.
Couldn't you just lower the model [-(a few)mm]?
gr5 1,843
The quick answer is: go to advanced tab, then quality section and in "cut off object bottom" enter 10mm.
The better answer is to figure out what went wrong in meshmixer such that it left something 10mm below your part and delete that.
Also keep in mind you should always look at your part in slice view also before printing it as this shows up lots of potential problems - make sure you scroll through EVERY layer at least briefly - you can use shift+up arrow and down arrow to go through layers quickly.
