Strange. You can mess with fan speed and observe it in the TUNE menu while printing. Did you try that? Try spinning it manually with your fingers. I'm guessing it's "gummed up" with some kind of dusty grease and takes 4 minutes to get started but then is fine after that.
Thank you for the response.
I am currently down to the board and I've tried setting the fan speed in the tune menu and they don't start. I've pushed the fan with my fingers and one of them started turning slowly that's the best I can get from it. On my last test print. the fans didin't start at all.
I've checked and they are plugged correctly I am gonna check the voltage from the plug next.
gr5 1,841
