Posted · Gluing 4mm flat object together
H i all
I'm Fairley new to 3d printing and after getting an Ultimaker Extended 2+ from ultimaker GB this year and with lots of help from Shaun Pullford i have manage to produce my objects but had one problem.
This was gluing 4mm flat sections together end to end, after many failed attempts i have got it
The Glue is Loctite 401
i smear a layer to both items then glue together holding them in place for 24 hours with strong dukt tape then hey presto like one sollid piece, i just have to sand the slight ridge that is formed.
Hope this helps someone.
All the best you printers
kev.
Posted (edited) · Gluing 4mm flat object together
Also Acrylic glue works well for PLA as it slightly melts the surfaces together.
You can use Acetone for ABS.
    • 2 weeks later...
    I've used Araldite, it's a two part epoxy resin. You have to mix it up for each use but you have time to align the parts. The thinner the epoxy layer the better.
