Err: MAXTEMP BED after a weeks use (UMO)
Posted · Err: MAXTEMP BED after a weeks use (UMO)
I bought a Heated bed upgrade to my UMO and have been using it for about a week now.
Today I started a 4hr print with Colorfabb XT, 255C nozzle and 70C bed....after 1.5 hrs machine 'crashed' meaning the nozzle glued itself to the print because of this alarm and I guess it shut down nozzle heater and bed.
Now I cant start the bed, temp is all over the place, 100C-32C-150C-500C-48C-130C like this every 2 secs..
Anyone know if its bed is faulty or have experienced similar ?
    After a weekend with fiddling, its the connector to the heatbed thats acting up, i've
    taken off the heatbed 3-4 times and 'retightened' the screws (when you tighten an already tight screw, you'll start to break the head when the screwdriver loose grip) But after a while the same error happens.
    For now it last longest then I jam something inbetween the wires sticking out and the wooden base.
    Take it all apart - check the connections. The error is from the temp sensor - not the heater itself. The temp sensor is the smaller 2 wires. Check the resistance - it should be about 108 ohms at room temperature.
    I took off the heater board from the bed and turned it around and added (more) solder to the
    4 points to the connector, seems errors stopped.
    (Read another post in this forum about badly manufactured heated beds and poor solder points)
    Good luck...
        • 24 replies
