Posted (edited) · Phone cases modeling
I'm trying to make a phone case for my iphone 6 recently
The dimension is not hard to find as apple have released a guide for doing that,
but how many spaces between the cases and the phone you would leave? 0.3mm? 0.5mm?
and what is your frame thickness? 1mm? 1.5mm? or 0.5mm?
What materials would you suggest? ABS? Nylon? or even others?
Thanks!!
    Posted · Phone cases modeling
    Hi
    You could have more clearance over the total length like 0.5mm less for the width say .2mm and .1mm over the thickness.
    Maybe ABS, XT or NGen as they have more flexibility than PLA. Nylon could be good but I'm not sure how easy it is to print.
    For thickness maybe go a multiple of your nozzle width. So for a 0.4mm nozzle try 1.6mm for sides top and bottom.
    Good luck and show us the final print.:)
