Nylon is really nasty stuff to print. Especially getting it to stick to the buildplate. Quite a challenge if you call yourself a newbie, but you will get it done too
A) Bed adhesion: Up to now did you use anything to help the print stick to the bed? Or are you printing on clean glass? If so, you have no chance. You definitely need something to improve adhesion. There are many options that should work, like valcrows hint. I had good luck with woodglue (D2) diluted in water and some puffs of window cleaner. There is also those adhesive sprays or surfaces like Buildtak. I think many work and everyone has to find their own favorite.
B) Moisture: Nylon is highly hygroscopic and soaks a lot of water from the air. If you leave it open on the bench for a day, it already starts to print worse. I always keep the spools in a closed plastic bag with several desiccants. I found some type that changes color when they are saturated so you know when to put them in an oven to regenerate. Also, if you have any relation to electronics, there are small cards packaged with sensitive microchips, that signal the level of humidity changing color from blue to violet above 5%, 10% and 50%. When I print small parts, I get the spool out of the bag just before printing and put it back immediately after. If the print takes longer, I put the spool in a bucket with a cap and only let open a slit to feed the filament to the printer. In there, I too put some desiccant bags.
If your filament is already soaked with water, you can dry it in an oven. I didn't have to yet, maybe someone else has experience? You will notice bubbling/spitting sounds from the hotend when the nylon has soaked water.
C) Type of Nylon: I haven't tried Taulman 618, only Bridge and 230. From what I heard, 618 is their first Nylon and they improved printability with each new type. So Bridge is probably easier to print than 618. The quite new Alloy 910 is said to be the easiest according to Taulman3D. With those newer versions they also reduced the hygroscopic effect. Do you have to use 618?
D) Print settings: Which print settings do you use? The last settings I wrote in my notes are Hotend: 240°C, Bed: 75°C, printspeed 30..40mm/s, layerheight 0,15mm. But that was for Nylon Bridge, no idea, if 618 is behaves very different. As always, a good bed leveling is crucial.
Good luck, sooner or later this stuff will have to give in to you
inserted some line breaks
valcrow 144
I'm sorry but your post is a little hard to follow.
From what I gather,
-You're trying to print nylon
-The print is coming off the buildplate after printing a brim.
-Your guy is writing custom gcode? or just slicing your object?
-Did he design your object/gcode? Is what you're trying to print an actual 3D model sliced into Gcode? or something else more experimental?
If you're having 'sticking' issues on the glass bed, you should try using blue tape cleaned with alcohol.
Lastly if you post pictures of your failures, it will help people here to diagnose the issues you are having.
