You have underextrusion. What material is this? PLA? Usually PLA doesn't peel off like that but that's common with ABS and easily fixed.
Still - what material is this and what temperature (temperature is set on the printer, not in cura).
I think the default temp is 210C and assuming PLA and with .3mm layer times .4mm nozzle times 50mm/sec that equals 6mm^3/sec. That's a bit fast for 210C and PLA. Try raising the temp to 220C and making your layer height thinner - try .15mm also slow it down a bit to 35mm/sec. That should fix much of the quality problems.
I used a PLA not ABS. I try your settings.Thank you
gr5 1,512
