What Sander said. You may be skeptical but that's probably it. More info here - this post and the next:
https://ultimaker.com/en/community/2872-some-calibration-photographs#reply-15396
Edited by GuestWhat Sander said. You may be skeptical but that's probably it. More info here - this post and the next:
SandervG 1,522
Hi @Inter, welcome to the forums!
Such behavior is often triggered by a loose short belt, or at least not as tight as it should be.
You can tighten it by loosening the 4 screws that hold the motor in place, push the motor down as far as possible and tighten the screws again.
What version of Cura are you using?
With different wall thickness settings it can also influence your print.
Looking forward hearing from you!
