Thanks.Expert -> Switch to quickprint
In the quick print mode you will be able to select ABS on the left hand side.
I usually select ABS on the little display on the ultimaker machine. Does this override the selection in CURA?
Also I hadn't updated the firmware for CURA 15.04.6 which I have been using to produce the gcode. the ultimaker was using th firmware for 15.04.2 - could this cause me problems?
IRobertI 473
